> > The plates are good and heavy duty. They are 1/2" thick with six Nelson studs. Strength wise they are all there they just need to be placed in the right spot.
> My mistake, I thought they were flat plates that you were going to be welding to.
They are flat on top to weld to but have six studs sticking out the bottom. [/img]
corrected image link
https://surveyorconnect.com/images/uploaded/20150507140516554b711c971af.jp g" alt="" />
Using A Tape Is Too Time Consuming For 6 Points?
> 3) The measurements / marks will need to be placed and removed several times. I need initial marks to know where to dig the holes. If it is a pin or strings crossing they will need to be removed so I can dig and build forms and then pour concrete. I will then need to be able to quickly relocate these points once the concrete has been poured to set the plates.
Isn't that what Batter Boards are for?
Batter Boards - Good idea.
Personally I think it would be a good time to meet the neighbors and ask for some help....just like the old days.
I have found that a screwdriver, through the tape handle, is quite capable of handling the dumb end of the tape.
Exactly, batten boards to the rescue.
BTW "put all cross boards at the same elevation for best results"
:gammon:
