GNSS Solutions VRS?
2 Users
(@ncdan)
I have tried to use the VRS function twice in GNSS 3.80.08 in the last couple days and its says "data not available". I'm new to processing my own data so I don't know if me or the Promark2 data. I have followed along with some of Mark Silvers videos and everything work great. Any help would be appreciated. Thanks
Posted : July 1, 2013 2:12 pm
Where are you?
Have you verified that the CORS you need actually have the data needed?
You actually want to do several checks. First go to the CORS ftp folders and check that it is there. Then go to the ufcors site and request the data there. You really want a yes at both.
Then check that the orbit data is also available.
Next check on the time and date of your data. Do not just note what Solutions says, also convert your PM2 files to RINEX and look in that file with a text processor such as WordPad.
After that you want to check what position your raw data thinks is right, because the CORS search is based on that.
As a check send some PM2 files to someone else to play with. My email is in profile.
Except you cannot attach files via BeerLeg. Reply instead to my email to you.
Posted : July 1, 2013 3:09 pm
