Hi everybody. Since I switched to Geoid 2009 my elevations have been running 3' too high, almost to the hundreth. Now why is that? Do you think it's because I am using Rinex dates? Or is something else going on? How do you guys get elevations off of TGO? What's your procedures when you post process? Thanks.
Are you checking to see that the antenna heights indicated in TGO are correct and in the right units at both base and rover?
Haven't thought of that. I'll have to check. Thanks.
