Creating Easement - Reserved From
7 Users
epoch-date
(@epoch-date)
In creating easements on an existing parcel, is it proper to use the term “reserved from” in the header?
“All that portion of Lot 00, Bla Subdivision, and projected Section 00, T.0 N., R.0 E., Bla Bla Meridian, County of Bla, State of Bla Bla, reserved from the Deed recorded Month 12, 1998, as Document No. 1998-123456 Official Records of said county, described as follows:”
Since this is creating a new easement in 2011, “reserved from” in the header seems appropriate.
But what about future transfers. Would the easement legal description need to be change from “reserved from” to “as per” the creating easement document.
I can see where the original 1998 deed would be called, and where a separate paragraph at the end would reference the easement creation document(s) by stating, “subject to Bla Bla easement(s) recorded in Doc…”
That’s why I’m questioning the usage of reserved from in the creating easement.
Posted : May 14, 2011 2:52 pm
Steve Gardner
(@steve-gardner)
Instead of "reserved from" I would say "being a portion of that certain real property described in.."
"Reserving therefrom..." is language I would use if it was in a grant of property that the grantor wanted to retain an easement interest in. I wouldn't say "reserving from the deed" though. You're not reserving from a piece of paper, you're reserving from the property.
Posted : May 14, 2011 2:58 pm
Paul Plutae
(@paul-plutae)
I would probably say 'as reserved in the deed'...
Posted : May 14, 2011 3:37 pm
Steve Gardner
(@steve-gardner)
But it's just now being created, it hasn't been reserved in any deed yet, right?
Posted : May 14, 2011 5:29 pm
don-blameuser
(@don-blameuser)
I agree with Steve. If I understand your situation, nothing is being reserved but an easement is being granted, so you just need to write a description of what that is.
Don
Posted : May 14, 2011 5:46 pm
Paul Plutae
(@paul-plutae)
I was under the impression that the easement parcel was being created from a reserved portion in a previous deed.
Posted : May 14, 2011 6:06 pm
charles-l-dowdell
(@charles-l-dowdell)
I would describe it as being "Subject to the following decribed easement for (purpose(s)-------, etc.".
Posted : May 14, 2011 6:23 pm
Evelyn
(@evelyn)
I would give the easement description then state the servient estate is . . . then give the legal for the parcel is being taken from, then state the dominant is . . . then give the legal for the parcel the easement is going to. This prevents the easement from being used for more than it was intended to be used for. There have been cases where an easement was given for one or two houses, and then a whole subdivision sprang up.
Evelyn
Posted : May 16, 2011 10:01 am
jbstahl
(@jbstahl)
Your first statement, here, has me a little confused. If the easement has already been "reserved" in a prior transaction, then that transaction has already "created" the easement. Yet, you ask, "In creating easements on an existing parcel..."
Typically, an easement is "reserved" across a parcel being sold when the grantor retains ownership of adjoining property which is to serve as the dominant estate benefiting from the reserved easement. The parcel being sold (from which the easement is "reserved") is servient to the easement.
A subsequent sale of the dominant estate should include the terms, "together with that certain easement reserved in document xxx ..." This language would ensure that the easement reserved from the first grant is specifically conveyed in the second grant.
This is where I get confused again. If the easement has already been "reserved," then it has already been created. The new description is simply recognizing that the "reserved" easement is appurtenant to the parcel being now conveyed. In such a case, I would recommend that the phrase, "together with that certain easement reserved in document xxx..." be included. If it's not included, the easement would still transfer as it has already been created and is already an appurtenance to the parcel. You're right in wanting to include it. Expressed language is always more certain that something left unsaid.
When easements are created by reservation, subsequent transfers of the servient estate would convert the term "reserving therefrom" to "subject to." This phrase might reasonably be expanded to say something like, "subject to that certain easement reserved in document xxx."
A sale of the dominant estate, or some division of the dominant estate, should simply contain the language, "together with that certain easement reserved ..." I'm not particularly fond of the term "as per," but that's just a personal preference. Always seems redundant to me.
JBS
Posted : May 16, 2011 1:41 pm
epoch-date
(@epoch-date)
JBS, the easements are new – just creating them now, so this is the first description for each one. The are all on one main existing parcel. The are to limit land use (within these small certain areas) if the main parcel is ever sold.
Steve Gardner seemed to address it effectively above.
The reasoning and anything to do with “reserving from” can be accomplished on the preface page, and the description(s) be on an Attachment.
Really not too much written about the usage of Reserving in Wattles or other description reference texts.
Posted : May 16, 2011 7:29 pm
