I'm looking to create a field report containing the same data one can get from the "Review Job" function in Trimble Access.?ÿ
Setups, deltas, staked data, HI/HT info ect.
How can I generate a PDF from one of Trimble's software packages that can do this?
Honestly, one of the generic ??as-staked report? will probably work for you within TBC, but you can also edit the formats and customize them to your liking as well if need be. ?ÿThe interface isn??t too bad to edit things and add fields you want or whatever.?ÿ
https://forms.trimble.com/globalTRLTAB.aspx?nav=Collection-62098
Download the SURVEY-Style sheet and copy to your datacollector, you can now custum-export a text file on the dc with all the data. If you??re comfortable with xml files then export to jobxml, you??ll find this under the fixed formats.
you can also do the same from TBC or if you don??t have that with the free Ascii file utility from Trimble. When exporting from TBC be aware that these exports are made directly from the job file you imported in TBC and NOT from the TBC-databases, so any modifications you made in TBC won??t appear in that export.
The Trimble ascii-file generator utility has been discussed here before. It sure is a handy tool!
Customized style sheets can really improve productivity and help out with QA/QC. If you are familiar with XML and XSLT it's pretty easy to develop your own.
