Corrected description question.
5 Users
 RFB
(@rfb)
I have a legal description that doesn't match the property. Actually, a piece was just left out.
I've corrected the description, now what do I do with it?
Is it time to get a lawyer involved?
Thanks
Rick:-P
Posted : September 16, 2010 8:03 am
(@deral-of-lawton)
In Okie if they left out a line from a previous description then you file another deed at the courthouse. It's called a scriveners error in Okie. No big deal and they happen a lot with the cut an paste from attorneys.
You just call it a corrective deed. It has it's own form.
Deral
Posted : September 16, 2010 8:17 am
 jud
(@jud)
You must be surveying a tract with the latest deed description to trigger the question.
What I do unless a lot and block type of description is to look at the original writing for the tract of interest. If they differ, I find out where it happened, survey using the original description and stating the reason for doing so on the survey. As a surveyor, I can write descriptions, I cannot write deeds and record them, that is for the owner to get done.
jud
Posted : September 16, 2010 8:35 am
(@stephen-johnson)
> jud
In Texas and in Oklahoma surveyors can and do create deeds and once they are signed by the proper parties can record them as the owner's agent. Mostly though L@#$rs do the deeds and owners or la234rs do the recording.
I have recorded more than one subdivision plat as the owner's agent and other forms. A deed is no different.
Posted : September 16, 2010 9:12 am
(@lamon-miller)
I would call the person responsible for writing the first deed and explain the problem. They should correct it for no charge.
Posted : September 16, 2010 9:35 am
 RFB
(@rfb)
THANKS GUYS, GOOD INFO!
:beer: :beer:
Posted : September 16, 2010 11:51 am
