Carlson Demo disabled SAVE/PRINT
5 Users
(@broken-lath)
One man band here,
Downloaded Carlson 2013 Intelli, (well more than) 20 days ago.
Have played with it for a week or so and have finally learned how to get my drawings done.
Demo had 6 days left, and I decided to purchase the software.
Local state dealer emailed my the license code this afternoon (4:00PM).
I jump in (8:30PM) to edit a drawing (did not register using emailed code)
"2dline" function disabled
"save as" function disabled
"print" function disabled
I cannot find anywhere to enter the code and I have about 1.X hours plus
editing into a drawing on the demo mode.
Any suggestions to deal with this on the fly?
FML
Posted : September 17, 2013 5:55 pm
(@stephen-ward)
Go to Help, About Carlson, then there should be a button at the bottom that says Change Registration or maybe just Register since you're on a demo copy.
Posted : September 17, 2013 6:13 pm
(@broken-lath)
Did that in the drop down menu.
Command Line showed this message:
"Unable to recognize command "about_scad". Please try again."
Posted : September 17, 2013 6:21 pm
(@broken-lath)
Nevermind,
I shut it down, dumped my changes.
C'est la vie
Posted : September 17, 2013 6:28 pm
(@stephen-ward)
When I ran the demo version last year it was full functioning. If you are having issues like that I would suggest a reboot of the computer and if issues persist I would do a clean install.
Posted : September 17, 2013 6:35 pm
(@cptdent)
Broken Lath, go to the Carlson website and download the latest build of the software you purchased. Use the registration number that the VAR gave you on the new install. A lot of people had problems with converting the demo disc.
Your dwg file should still be good. If you saved it in a project folder you should be able to open it with your new download. If you dumped it, recover it from the recycle bin, You may not have lost a thing.
(On the Carlson website under Survey with embedded AutoCAD in the Discussion Groups you will find a step by step on how to load the latest build. These steps work on all versions of Carlson. Sounds scary, but it works.)
Posted : September 17, 2013 6:50 pm
(@broken-lath)
Sorry all,
I believe the issue was on my end.
I had been saving a number of versions some of which being 2007 CAD dwg.
For no apparent reason, when I popped open the drawing that looked like
the last revision, all these errors occurred.
I dumped the changes and opened a drawing back up and all worked out fine.
The only strange thing was that it would not accept the license key.
But it had all the functions that I was used to.
I can only guess that I was working in a 2007 CAD dwg and the 2dline was not an option.
As for the save and print being blocked...... I'm at a loss.
Thanks for those who responded so quickly. Thanks guys.
Posted : September 17, 2013 6:58 pm
(@coady)
Lath,
Just wanted to let you know, you should be eligible for ICad 2014.
I bought the 2013 just before 2014 came out and was told by
support not to update 2013 but to install the 2014. All the best.
Posted : September 18, 2013 2:59 am
(@jerrys)
If you just purchased the software, the serial number you were furnished is for Carlson 2014. They would not sell or furnish a serial number for the 2013 version at this point.
Posted : September 18, 2013 5:26 am
