Good Morning
I am a little confused about measuring the HI on the BRX5 , using Carlson SurveCE 4.07?ÿ ?ÿAt first I thought the HI was measured to the base of the unit (top of the 2 meter pole less screws)?ÿ ?ÿBut then I read there are measurement tabs.?ÿ ?ÿ ?ÿ I cannot find ANY literature or videos that explain this.?ÿ Does Carlson SurveCE 4.07 self correct ? so If I insert the 2m it will add to the tabs ??ÿ Or am I supposed to insert the measurement to the tabs ??ÿ
Signed?ÿ Daved and confused?ÿ ?ÿ ?ÿ ?ÿ ?ÿ ?ÿ ?ÿ ?ÿ ?ÿ ?ÿ ?ÿ ?ÿThank you?ÿ?ÿ
If you are using a 2m pole, then use 2m height.?ÿ ARP is to the bottom of the unit.
Thank you VA LS 2867 !!!?ÿ
I am relieved to know I have been doing it correctly (by accident)?ÿ ?ÿ ?ÿI really love these units, as both network rover and base/rover survey tools Have a great weekend !!?ÿ?ÿ
Dave Harris?ÿ
