Carlson and Google Earth Pro
ctompkins
(@ctompkins)
Has anybody had any luck with importing Google Earth Pro images into projects?
I have to use the standard version of Google Earth in order to get it to work.
Posted : March 18, 2015 9:32 am
Glenn Breysacher
(@glenn-breysacher)
I'd like to know about this too.
Posted : March 18, 2015 10:46 am
cptdent
(@cptdent)
I haven't had any problems inserting the images, of course they are not geo-referenced or anything, but that can be delt with.
Posted : March 18, 2015 11:00 am
djames
(@djames)
command -" Google_image" - itellicad version wait for the time out and follow the directions.
Not sure why this is not of the Standard Carlson Survey, use to be.
Posted : March 18, 2015 11:18 am
ctompkins
(@ctompkins)
I am using the Carlson Civil Suite...I can get the image to come in normally, but the Images> Place Google Earth Image command doesn't work unless you are using the regular version of Google Earth. I have tried it several times with Pro and it locks up and stalls out. Would like to have some sort of idea of whether or not this is a Carlson issue or a Tompkins issue.
Posted : March 18, 2015 12:11 pm
twdotson
(@twdotson)
It appears the COM API is missing from GE Pro, it broke some of our functionality also. I would suggest you begin looking elsewhere for imagery.
Posted : March 18, 2015 12:35 pm
ladd-nelson
(@ladd-nelson)
If you're using Carlson Civil Suite:
1. Click Settings -- Carlson Menus -- GIS Menu
2. Click GIS Data -- ESRI ArcGIS Services -- Retrieve Map
3. Enable the World Imagery option as shown below:
Posted : March 18, 2015 2:00 pm
ctompkins
(@ctompkins)
I tried what you said and it said "Communication Error"??
Not sure what that means but it acts like it needs the internet to adjust those settings.
Posted : March 18, 2015 2:11 pm
ladd-nelson
(@ladd-nelson)
Correct, the ArcGIS Online Services requires an Internet connection to retrieve the data. If your computer has an Internet connection, see if it can reach http://server.arcgisonline.com via a web browser. If it can reach this URL, check to see if you have the most recent build of Carlson for your version by visiting http://www.carlsonsw.com/support/software-downloads/?product=Carlson . If this doesn't bear any results, a call in to the Carlson Technical Support Group would be the next suggested course of action.
Posted : March 19, 2015 8:44 am
