Carlson 2014 Survey for Intellicad & PDF Files
(@surveysc)
Anyone know how to write a PDF file from Carlson 2014 Survey for Intellicad?? Thanks for your help.
Posted : 09/04/2014 11:53 am
(@djames)
Download print driver call pdf95 . Works like a champ.
Posted : 09/04/2014 12:31 pm
(@landman)
PrimoPDF works also.
Posted : 09/04/2014 12:49 pm
(@larry-p)
Creating a PDF is the same as printing. You have to have software that creates pdf's installed on your computer. To know whether you have such software installed, check your control panel. If you do have something that does that it will appear on the list of printers when you go to plot the drawing. If you do not have something like that, the suggestion from the other gentlemen should work.
Hope that helps.
Larry P
Posted : 09/04/2014 1:17 pm
(@cptdent)
Type PLOT on the command line. Under Printer/Plotter, Name window, look for "DWG to PDF.pc3" as a plotter selection.
Posted : 09/04/2014 2:29 pm
(@bush-ax)
File, export, standard export, then save file as pdf. you will have to adjust page to your scale but it works.
Posted : 09/04/2014 3:39 pm
