C.Y.A.
(@doug-jacobson)
Note on a Record of Survey:
"This survey is a retracement of Record of Surveys Filed in Book X at Page XXX, Book Y at Page YYY, Book Z at Page ZZZ and there may be alternate positions for corners. Survey lines established in Section AA & bb TxxS RyyE may or may not agree with lines of occupation" (Emphasis mine) Guess he was pretty confident of his solution. I get to resurvey and break down Section bb.
Additionally there are two monumented Standard Parallels about 5 chs. apart that were surveyed in the 1800s, early 1900's mid and late 1900's.
The N-S centerline of Section bb is called out in at least two surveys as going to the northerly !/4 Corner then to the Southerly one. The last survey doesn't show the centerline, just a tie between the two "1/4 cors."
For Keith, the Standard Parallel was originally rerun in the 1920's and reestablished in the 1940's "along a latitudinal curve".
DJJ
Posted : May 22, 2011 1:15 pm
(@keith)
DJJ
That's the way it was sposed to be run!
Posted : May 22, 2011 2:55 pm
7th Standard Road?
Posted : May 22, 2011 2:58 pm
(@doug-jacobson)
DJJ
Yes, I thought you'd appreciate someone from the last centuy understanding the concept.;-)
Posted : May 22, 2011 4:47 pm
(@doug-jacobson)
Dave
> 7th Standard Road?
Copus Rd.
Flat-not much brush;-)
Posted : May 22, 2011 5:05 pm
Dave
I see what you mean. There are squares to the south and squares to the north with a strip of rectangles in between 😉
Posted : May 22, 2011 5:16 pm
Doug
I remember visiting my Dad at the office on H Street sometime in the 1960s and he showed me the "computer" which was in an office across the outdoor hallway thing near the construction company office. All I remember is it looked like a metal cabinet about the size of a washing machine but bear in mind I was only 5 or 6 years old so my perceptions and memory could be skewed. It seemed like a big deal to see a "computer" but it wasn't very impressive to look at.
Sometime in the last 10 years he told me they were doing a huge (multi-township) Record of Survey down there and the computer I had seen was used to aero-triangulate the positions of corners from the aerial photogrammetry. They put photo panels on the found monuments. He was hired by the firm to be Project Engineer on a big 30" water project (not related as far as I know); I don't know what his involvement was in this project other than he was a partner in the photogrammetry firm. He knew they did the control with EDMs which you can see on the R/S maps.
I always wondererd where that was, now I know.
Posted : May 22, 2011 6:45 pm
(@doug-jacobson)
Dave
If it's the survey I'm thinking of there are 13 sheets plotted at 1"=2000'. About 18 sections per sheet. One -or anumber of- Tps. have sections that are about 1 mile wide by 120' going up against the Std Parallel.
DJJ
Posted : May 23, 2011 5:34 am
(@eapls2708)
With a note like that, I hope that the surveyor located and did some analysis of the lines of occupation.
There are instances where there is conflicting survey information and conflicting occupation evidence where such a note may be warranted.
Without analysis of the occupation and some notations or narrative regarding discrepancies, a note like that is making the statement that the surveyor punted.
Posted : May 23, 2011 11:07 am
(@doug-jacobson)
I think he tied and considered lines of occupation and prior surveys. He was a good surveyor. The statement just hit me as odd.
But he was dealing with a somewhat complicated situation.
Check your e-mail.
DJJ
Posted : May 23, 2011 11:34 am
Being on the boundary between two meridians probably has something to do with the confusion.
Posted : May 23, 2011 4:01 pm
(@doug-jacobson)
You've got the right idea. The Centerline could be based on either of the two Parallels or occupation.....If you e-mail me I'll send you some more info.
DJJ
Posted : May 24, 2011 12:31 pm
