"*" by latency reading in Carlson SurvCE 2.60
2 Users
(@dmyhill)
What does it mean?
I know what latency means, but not the *
Posted : May 30, 2012 11:40 am
(@matthew-m-filus)
From the SurvCE manual @ www.survce.com
Within Monitor Skyplot, you will typically see a progression of messages from "Insufficient Data" (not enough satellites) to Autonomous, Float and then Fix. There are two fixes provided: Initial Fix (with *) and Confirmed or Verified Fix, which removes the *. The Verified Fix occurs when the same RTK position is found by a secondary fix calculation. Usually, the Verified Fix occurs within seconds of the Initial Fix.
Matt
Posted : May 30, 2012 4:40 pm
