Break the Record
I don't like to break the record, but of course sometimes it's necessary to show record vs measured on a plat. The last one I did had a section line of record that I surveyed in 2010. Resurveyed it for a BLA.?ÿ
I put it into the drawing and drew the line with the new locations and slapped a bearing/distance on it. One thing that can get me into trouble is having old and new points in a job. I try to always separate them with layers.?ÿ
Well this time I had a bearing of S89-31-37W, distance of 2651.42' between the section and 1/4 monuments for record and S89-31-36W, 2651.42' for measured.?ÿ
I didn't believe it so I looked through the TBC and C3D files and sure enough it's correct. Record is 2651.424, measured is 2651.416, the one second is where the "error" is. This was using 4700/5800 combo's 10 years ago compared with R10's today. I guess we have our bubbles adjusted.?ÿ
Posted : January 9, 2022 12:01 pm
Wow!?ÿ Just wow!
Posted : January 9, 2022 12:13 pm
Its common. Modern tools are pretty good.
(Why didn't you just whack the monument with that 6lb sledge, to make measurements agree)
Posted : January 9, 2022 1:05 pm
A few years back I established a small control network for a nearby city and ran duplicate 1-hour static sessions on the stations using Trimble 4000SSi receivers and 2-meter fixed-height tripods.?ÿ A few months later I needed to use a couple of them about 1/2 mile apart to reset a 1/4 corner, so I set up a regular round Leica prism over one and a total station (Leica TCRA1102plus or GeoMax Zoom 80, don't remember which one) over the other.?ÿ When I shot the backsight distance I was dismayed to see a discrepancy of 0.06' from my own record distance.?ÿ Then I remembered that I had the data collector configured for Leica mini-prisms, so I changed the BS prism setting to Leica round and reshot the backsight.?ÿ The discrepancy dropped to 0.006'.?ÿ Close enough for me!
Posted : January 9, 2022 4:01 pm
