Bluetooth to robot
9 Users
JB
 JB
(@jb)
I've been using the Hayes bantam bluetooth radios for a few years now and really like them. I think I may have messed one up when I took the Inst off the tripod and forgot the cable was plugged in. Gave it a bit of a tug, and I think (hope) I just pulled a wire off an internal connection.
I will be upgrading to a Carlson Surveyor+ in the near future. It's actually on my desk, I just have been too busy to learn it. Anyway I'm wondering if any of you have tried a bluetooth "dongle" direct from the DC to the inst without the rover radio. Just DC and dongle. If I can get 500'-600' out of it I'll be fine. I heard Butch at Carlson got over 600' to a gun with built-in bluetooth.
I have an email into Troy at Geo-tronics already.
Any thoughts appreciated
TIA
Posted : July 20, 2013 12:29 pm
ps8182
(@ps8182)
I've been using a pair of Parani SD1000 radios for five years and love it. This year I tried paring one of the radios to the internal bluetooth in my Ranger 3 and haven't looked back. My range was cut in half, but it still seems to cover 99% of my shots and I love not having a cable or radio at the rod. I still carry the other radio just in case, but I haven't had to use it yet.
Posted : July 20, 2013 12:55 pm
The Pseudo Ranger
(@the-pseudo-ranger)
How far can you get with the internal BT in a Ranger? I thought regular blue tooth was only good for about 30'? Does the Ranger 3 have "long range" BT built in?
Posted : July 20, 2013 1:31 pm
Class 1 BT is spec'd at 100m, but with the right antennas a pair of Class 1 units can go up to 1km.
Posted : July 20, 2013 3:54 pm
cf-67
(@cf-67)
I was suprised to get about 60 metres range from my Carlson Mini to a Sokkia SRX. Not enough of course but alot further than it's supposed to work.
My crusty old mentor/work mate keeps breaking the antenna on the RC PR4 - the proper longrange radio/prism search device for the SRX - so I thought I would just try the direct DC to gun approach. I'm almost tempted to open up the mini and see if I can add a better antenna somehow (it must just be a tiny thing attached to the board and could probably be improved upon). 150 metres would cover me most of the time.
or get one of these...
http://apac.getac.com/news-and-events/news_2012101071.html
I think all DC's should be coming with longrange bluetooth - they should be able to cram a Parani SD1000U into them somewhere.
Posted : July 20, 2013 5:04 pm
ps8182
(@ps8182)
The Parani at the gun has the long range antenna on it and I get 500' when paired with the data collector. I get 1000' with a Parani at the gun and at the dc, but rarely need that kind of distance.
Posted : July 20, 2013 6:05 pm
shawn-billings
(@shawn-billings)
I've had the same experience.
Posted : July 20, 2013 9:06 pm
hardline228
(@hardline228)
When you say long range, do you mean the 5" 5dBi Dipole Antenna or the 9dBi Patch Antenna?
Patch
Or
5"
I took delivery of my first pair of SD1000's today and am amazed at how small they are, but I only bought two 5" antennas.
Posted : July 24, 2013 8:12 pm
jimmy-cleveland
(@jimmy-cleveland)
I have two of the SD1000 units, and I get about 600 feet with the small stub antennas. I bought two of the 5 inch antennas, but have only used them once, before I knew the range I could get with the short antennas.
Posted : July 24, 2013 8:57 pm
I use the 5" antennas daily, and have gone (best I can recall) up to 1,900' with them. I got half a mile with a 5" on the DC and a patch at the gun.
Posted : July 24, 2013 9:32 pm
hardline228
(@hardline228)
Good to know, that was my plan based on what you said in another thread.
I'm really interested to know what range he's getting out of the internal bluetooth on his collector.. sounds like he isn't even using an SD1000 on his data collector but just one of the larger patch antennas at the gun.
Posted : July 24, 2013 9:37 pm
cwlawley
(@cwlawley)
What Butch is telling you is correct. We have done our own independent tests and found that in the right conditions we could get 600-750 feet. Is this the best way? No. The connection is slower that than that of a radio or a built in long range Bluetooth meaning that under certain conditions you will see a loss of signal or at least some fluctuation. This is also line of sight. At the max distances, something as small as a car passing between you and the instrument can cause a loss of connection. Again, if you are looking to work under 600 feet all the time, it will probably work fine. Unfortunately, if you ever get in a tight spot where you need that extra couple feet, you'll never get it.
If we can help please let me know. Take care.
Posted : July 24, 2013 10:19 pm
