Bluetooth DC to NonBT Instrument....
5 Users
 wgd
(@wgd)
Is there a BT device and cable combo that I can use to make my BT Nomad communicate to a Topcon 311?
Posted : 24/06/2016 10:26 am
(@cameron-watson-pls)
might be able to do it with a Piranni SD radio. Not sure if they're configurable enough to make one radio talk to your Nomad though. I used one at each end when I was doing it that way.
Posted : 24/06/2016 11:21 am
(@lee-d)
I don't know what a Topcon 311 is but I don't think it's robotic.... Nomad has a 9 pin port if I'm not mistaken.... I believe the device you seek is called a cable. Apologies in advance if I'm being ignorant.
Posted : 24/06/2016 6:18 pm
(@cwlawley)
^Wow.
Yes, there is an cable adapter to a bluetooth adapter that would allow you to pair a GTS-300 series with a bluetooth Nomad. I believe I have seen Troy Deaton make some. May want to contact him, just search Deaton's Geotronics.
Posted : 24/06/2016 7:16 pm
 wgd
(@wgd)
Lee D, post: 379001, member: 7971 wrote: I don't know what a Topcon 311 is but I don't think it's robotic.... Nomad has a 9 pin port if I'm not mistaken.... I believe the device you seek is called a cable. Apologies in advance if I'm being ignorant.
I'll keep that in mind.....
cwlawley, post: 379006, member: 3114 wrote: ^Wow.
Thank you, sir.
Posted : 26/06/2016 5:01 pm
(@jerrys)
One of the keys to making this work is knowing the communications parameters of the GTS-310 series. The parameters are unalterable on that instrument.
Baud Rate = 1,200
Parity = Even
Word length = 7
Stop Bits = 1
You will need a Bluetooth adapter that can be configured in that manner. The instrument never knows the Bluetooth adapter is there. You would simply plug the 9-pin cable you use with the data collector into the Bluetooth device and pair it with the Nomad.
Posted : 27/06/2016 10:01 am
