Bad RTK or Not?
15 Users
ridge
(@ridge)
Small mountain Sub in some not so perfect GPS conditions. High mountain directly to the east and scatted pinion pine and juniper trees. One section marker (witness corner) was about 15 feet west of a maybe 200 foot high vertical wall and then there were two UDOT markers directly in line with the vertical wall. Mountain cliff (wall) runs north/south. First trip out I found these markers but had a hard time with GPS fix. Never did get the UDOT markers but second hike in I was able to get a GPS fix after waiting for about an hour. I didn't have all that much confidence in the results. So today I got back there with a Geodimeter 620 and my son-in-law for help and shot the WC from the highway below.
Below is the sort of surprising results. The GPS questionable fix appears to have been just fine.
Point Coordinates Listing
North East Elev
GPS RTK May 20th hard to get fix (had to wait about an hour for 5 SVs
4739.88 11364.81 7073
4739.87 11364.85 7073
Sept 17, two temp CP's on tripods (¼ mile apart) with 3 minute GPS RTK, set prism and total station in tribrachs after GPS observations. Shot WC point about 100 feet East and 50 feet higher. So these GPS CP's were further away from the cliff on the edge of the highway (another 100 foot drop off into a lake) but still only 5 SVs).
All total station shots to a held prism pole.
4739.875 11364.82 7073
4739.87 11364.82 7073
4739.87 11364.84 7073
Fairly dated GPS equipment also – Trimble 4700's and TSC2.
It's going to be good enough, ain't going back!
Posted : September 17, 2014 8:36 pm
I've heard that as long as your RTK is generating numbers, you're pretty much golden. I trust that you won't charge your client for actually checking a number generated via RTK, right?
Posted : September 17, 2014 8:45 pm
ridge
(@ridge)
I've done enough RTK over the last 15 years to know you can get bad numbers. Of course what is bad and how far is bad is a relative term (to some of us). But anyway, I considered this a problem zone and so I checked it. Also the UDOT's were likely only going to be measured with a total station.
Anyway, for what I'm doing a tenth or so is plenty good for me, the county and my clients. They don't get to pay for an extra five days work to get every new corner measured in under a hundredth. My expectation is that the future lot owners will use the monuments as set and found and not fuss to have them tuned up (moved or kicked about) to make them measurement perfect.
But hey, if you are ever in Utah surveying, you're welcome to go criticize the work, point out the deficiency of my RTK, and move these 62 new lot corners a few hundredths to measurement perfect. If you can get paid for the exercise then you truly are a survey god. Nobody else cares!
Posted : September 17, 2014 9:08 pm
Okay, so is there something WRONG with your RTK system that you're worried about getting "bad numbers" (as opposed to "good" numbers, presumably)?
I mean, you did get NUMBERS, even if it took you a while. Isn't that the main thing?
Posted : September 17, 2014 9:22 pm
ridge
(@ridge)
I've had bad fixes before but these usually bust 5 feet or so. In pine trees you can get say a half foot difference with observations taken one right after another (while fixed). But a total station will whack out also in certain conditions. So there is nothing perfect. I'd say the real danger is technology in the hands of those that don't have enough experience and realize the limitations of the tools they are using.
Posted : September 17, 2014 9:34 pm
So, what you're saying is that you really don't have any confidence in your RTK-generated positions until you've checked them by some other means?
Posted : September 17, 2014 9:42 pm
Note to Leon: starting a thread titled "Bad RTK or Not?" is like handing Kent a hammer and saying, "Hit me, please."
Posted : September 17, 2014 9:51 pm
Kevin Samuel
(@kevin-samuel)
:good:
Posted : September 17, 2014 10:22 pm
ridge
(@ridge)
I don't have total confidence in any measurement system until I've done some redundant checking. There are certain conditions where I've experienced problems with measurements of all sorts where I don't trust the "numbers" until I've either done enough redundant measurements to gain some confidence or used two different systems one which I trust more than another for those conditions.
Under good conditions RTK will give excellent results. Over long distances (a mile or more) I would have much more faith in a RTK measurement than a multiple leg total station traverse.
Every RTK shot has up to a cm in slop. So if you are measuring 2 cm might not get such good results. But I've tried a lot of things over the years. I've compared 3 minute RTK observations to fast static. I've compared 5 second RTK to everything including long term static. I've compared RTK to total station measurements. My conclusion, yup, you got that cm floating around in there, other than that RTK works very good. Get the cm in opposite directions at the ends of an inverse between the shots and you got a couple of cm. Sometimes it's about spot on. For the work I do my clients can live with it and the savings in time and convenience.
One of the last things I'd do is go out and traverse say 3 miles thought the mountains with a good total station, miss close a few tenths (after least squares repair) from some RTK surveyor's direct measurement and declare that RTK is bad, the guy was an idiot and should be turned into the board for poor surveying.
Posted : September 17, 2014 10:26 pm
Jim, that strikes me as completely unfair. Leon was just discussing both (a) his misgivings about the correctness of his RTK results and (b) how he went about "checking" them.
We cannot fault him for that, can we? I mean, my impression of Leon is that he's a somewhat earnest guy who uses RTK because his clients want the speedy anwers it provides and don't really care whether they are correct or not, but he himself is savvy enough to realize that he needs to check it any way he can.
Posted : September 17, 2014 10:36 pm
seb
 seb
(@seb)
I realise there are economics involved of course but I haven't used a GPS only unit since early 2007.
GNSS units are not that expensive anymore so if you are using RTK for anything, why would you not avail yourself of the extra satellites and productivity?
Posted : September 18, 2014 1:07 am
Kris Morgan
(@kris-morgan)
And the static snob returns to the board to lambast anyone who dares use a procedure that differs from his.
Glad to see you back.
Posted : September 18, 2014 7:26 am
Glenn Breysacher
(@glenn-breysacher)
:good:
Posted : September 18, 2014 7:51 am
ridge
(@ridge)
I doubt Kent would use a GNSS RTK if you gave it to him free! For the rest of us RTK seems to work pretty good.
My equipment has about reached (or past) it's better days. Considering that at this point if I bill an hour 90% goes straight to the bottom line, (everything paid for for some time) and I also don't work all the time at surveying, life is OK. Most large firms are doing good if 10% of gross ends up on the bottom line. But they have employees to manage and all the finest toys.
If I see the world picking up and a brighter future maybe I'll go ahead and invest a half years billing in new equipment and work an extra half year to pay for it. Maybe I'll do something else. I'd guess I'm about twice your age, so another decade is about all I could plan on being able to work in surveying assuming my health holds good.
Posted : September 18, 2014 10:10 am
Pablo
(@pablo)
LRDay,
I work considerably with the BLM and their chief geodesist locally. He's been a wealth of information. He has always said, if you can reinitialize on a point it is usually good. Have you tried that technique? I often will change the H.I. as a check on the reintialization.
Pablo
Posted : September 18, 2014 11:05 am
:good: :good: :good:
Posted : September 18, 2014 11:38 am
ridge
(@ridge)
On more important points (like section corners) I always reinitialize. For this little sub I did it for every set corner. Get a fix, make an observation, then dump the antenna, wait to get a new fix and shoot the marker again. If the two measurements aren't "about" the same (a few hundredths) then you may have a bad fix in which case you would do it a few more times and hopefully at different times of day. Even if fixed if you can't get good comparable results you are just in a condition where GPS is not that good. Maybe at a different time of day and SV arrangement it will work. You need all the SV signals you are using coming in without going through vegetation. If you have more than enough SV's sometimes you can figure out which SV's you may disable to improve the result's (or even enable fix). At my first visit to this point I couldn't get a fix at all. Some points just can't be measured with GPS so you have to use a different method for those. I been at this a long time.
I went back later in the day and after waiting for SV's in the western sky, got a fix, dumped it and got another fix which turns out were good. I just didn't like the condition of the site and wanted some further conformation (plus the UDOT markers were under the wall (didn't even try GPS on those).
This is what I consider a more critical boundary line because it's between federal (Forest Service) and my client (private). I not marking the section corners just using the Forest Service markers from 1969. Can't be to cautious on these now can we?
Posted : September 18, 2014 11:51 am
Another way to do this, is to assess the multipath in your environment, and move the gps to a LESS multipath environment, that is within 15' or so, and re-observe, then use compass and tape to CHECK between them. This gives you the redundancy, that lets you find a bad init.
When you do find a bad init, then, the games begin... pick a third location, and compass and tape between all 3 points, and now you find the bad one. OR TWO. I have found that certain times of day, when the sats are just right, well, they just yield more bad inits than others.
Posted : September 18, 2014 11:56 am
I appreciate this report of your results. It is a beautiful story. When things check that well it almost brings a tear to my eye.
Posted : September 18, 2014 12:29 pm
The ugly little secret is that RTK is actually processing the data, like static does. Of course the big difference is you can look at the data in real time, if you wish to invest the time you can let the RTK "cook" and get a position.
I've never, never seen one of those be wrong, it's the quick ones that get you in trouble.
If you think about it RTK offers such an advantage over static.
You don't need to leave the site (or download to your laptop and process) to find out the real numbers, and you can check everything, use Static at the same time as the RTK and you have another check. Most people just don't use it that way or think that way, they think it's all separate processes that can't be intermingled.
One thing I don't understand, and maybe someone has done it, why not have the DC import local CORS data over wireless and then internally process a static base session or even a rover point right there in the field, seems so easy. The data is all available.
Posted : September 18, 2014 2:21 pm
Page 1 / 3
