ALTA and Relative Point Precision
1 Users
(@iwisuri)
I am running a survey through Trimble Business Center. Assume my Least Squares Adjustment is correct. I now have to check my RPP for the monuments.
ALTA says 0.07 plus 50 ppm. So I inverse between each pair of mons, calc the 50ppm and add it to the 0.07'.
Here is the question:
Do you then take that number and compare to the semi-major axis for each mon that it corresponds to and see that it falls under it?
Do I have the RPP method correct?
Posted : 31/03/2016 7:15 am
