Advice on connecting a TCRP 1202+ using a RH16 radio handle.
1 Users
Michael720
(@michael720)
I have a Leica TCRP 1202+ firmware v9.03 using a RH16 Bluetooth radio handle. I am trying to connect to a Leica CS15 using a CTR16 cap. I am able to set up the 1202 to see the RH16 in its devices so i think that side is set up properly. however, in my CS15 there is no TCRP 1202 option in my model list.
When I run the connection wizard I am able to find the radio handle device but I get the message "Connection to the total station could not be established" when i try to connect.
Is my CS15 data collector that is running SmartWorx Viva 5.61 not compatible with the TCRP 1202+ with Survey 9.03? if so does anybody know what software I need for the CS15?
Posted : November 1, 2018 3:31 pm
Michael720
(@michael720)
I solved this, the problem was that I had "GSI Output" and "RCS Mode" set to port 2. Once I deactivated them leaving only "GeoCOM Mode" assigned to Port 2 (handle) The CS15 was able to connect without error.
Posted : November 8, 2018 4:00 pm
