Accept or reject?
28 Users
Norm
 Norm
(@norm)
There are aliqout corners at each end of the straight line with corner records. The box is described from the west corner. The description was created at the same time the corner record was 35 years ago. "400 ft east of the .....corner, thence south..., thence east..., thence north..., thence west to POB. There is no record survey. There was no recording law 35 years ago. The boxed lines are fenced and there are re rod with no Kaps at all four corners and the aliquot corner. There is no boundary dispute at this time. If it's important to you the distance from the straight line to the NW corner of the box is half a foot and it on a hilltop. The measured distances fit the deed distances ok if that is an issue for you. Accept the rerod as the boundary? Does section line bend or are the rerod treated as closing corners? If so, what imact is there on the back line? Does the owner of the box have unwritten rights in the adjacent alquot part? Inquiring minds want to know. Come on now, this is a common situation, right? Let's air some dirty laundry.
Posted : July 31, 2012 2:53 pm
adamsurveyor
(@adamsurveyor)
My immediate reaction is to accept the monuments. The section line "bends" through them. My presumption is that the original surveyor of the box set the corners with reasonable care and precision for the time to being on line. Nothing you have said would overcome that presumption for me.
Posted : July 31, 2012 3:06 pm
Keith
(@keith)
Well, if one is a line bender, then the section line will go through the monuments that were supposedly established on the section line.
But, if you are a senior line unbendable surveyor, then of course the monuments that are not on the instrument straight line between the senior corners will be off line and an overlap will exist.
I think I have repeated my story many times about my 1/16 sec. corner monuments were not set with micrometer accuracy and may be off the senior line, but it is my opinion of course that the senior line bends through those junior corners.
Keith
Posted : July 31, 2012 3:07 pm
spledeus
(@spledeus)
i take it the triangle to the north has record title in another party? probably no boundary agreement or other document clarifying the locus?
i would show the whole thing just as you have it. inform your client that he may not have record title to the triangle but he may have acquired title by other means. location complete, title issue to attorney, drinks are on the house.
Posted : July 31, 2012 3:40 pm
Norm
 Norm
(@norm)
...and a dispute where none existed.
Posted : July 31, 2012 3:51 pm
Kris Morgan
(@kris-morgan)
You can't cross the Senior line, ever. So, I'd show my heavy line around where it was supposed to be, and use the Southern senior corners, and show the polygon to the North, as in conflict and be done with it, unless that break is like a foot or something, then I'm not pissing people off for a foot.
Posted : July 31, 2012 4:02 pm
jud
 jud
(@jud)
Unlikely a depute, the section line is senior and I don't believe in bending them because of the potential for unintended consequences that bending the line may cause others. Would probably use the unrecorded monuments as closing corners. Again this would be a judgement call that is unique to this tract considering this tract and the conditions, land and owners, and other evidence around it. Not enough data given to make an informed decision, unless a rule is applied and a quick sprint to the next job is the object.
jud
Posted : July 31, 2012 4:10 pm
clearcut
(@clearcut)
In my state, my survey would only be an opinion. Either solution is challengable.
Choose wisely and go with what you find most defensible. Knowing full well there is no right answer other than the one resulting from landowner or court action. Make yourself aware of how your state's courts have ruled on similar cases.
Bending the line may keep peace, and may be a low risk choice, but it is not guaranteed against being contested.
Posted : July 31, 2012 4:11 pm
Brian Allen
(@brian-allen)
Ditto Adamsurveyor.
Posted : July 31, 2012 4:17 pm
Dave Ingram
(@dave-ingram)
The heck with Junior / Senior
Unless the same person owned North and South of the aliquot line, the owner to the South that created and conveyed the box can NOT sell something he did not own North of the line. Period! End of story!
Now there may be some basis for adverse possession, but that's for the judge to determine.
And there may be some basis for acquiesence, but that would depend on state specific law.
I wish Gene Kooper still posted here; he had a good take on when and why senior lines bent through junior corners, and when and why they didn't.....
Cheers,
Dugger
Posted : July 31, 2012 4:27 pm
lndbtchr
(@lndbtchr)
Agreed, you can't sell what you don't own, and unless the rebar are noted in the written desc they really are not record corners.
I know it hurts but I think the parcel cors are wrong.
Posted : July 31, 2012 4:32 pm
Keith
(@keith)
There ya go line bender!
What's the problem? 😉
Posted : July 31, 2012 4:39 pm
clearcut
(@clearcut)
Even the BLM now recognizes a cc may warrant kinking a line instead of the old hard and fast rule of amending corners. Either way, keep your eyes open and know that either solution can prevail in court and may hinge on the most minute of details.
Posted : July 31, 2012 5:01 pm
spledeus
(@spledeus)
Avoid a dispute by abandoning the triangle. Go for dispute by claiming the land. How does the other end fit? Can you call the far monuments out to make up the difference? If you do not know who set the monuments, why should you trust them?
We have a 400 lot land court subdivision from the late 60s. Realtor set pipes to market the lots. It is rare to find one within 0.5' of a corner. It was marketed to retiring folks and for my life it was called the cemetery with lights.
Posted : July 31, 2012 5:06 pm
Keith
(@keith)
clearcut
Do you have an example of BLM actually bending through a CC that is found to be off the senior line?
As you know, the practice has always been to amend the original CC monument and set a new one on the actual senior line.
Which State?
Thanks,
Keith
Posted : July 31, 2012 5:08 pm
clearcut
(@clearcut)
clearcut
> Which State?
> Thanks,
> Keith
Ca.
I recall Lance Bishop was showing one off at a presentation not too long ago. I think it was part of a survey they did in So Cal for BIA trust lands.
Posted : July 31, 2012 5:17 pm
Not Enough Information To Accept Or Reject
Once one has left the westerly point of commencement this is a metes and bounds description.
You have supplied no metes and no bounds, only a totally inadequate sketch.
The language describing those metes and bounds tells you what to do.
For instance if the ties from the West says, "along the aliquot line" and/or the third course says "to the aliquot line" and/or the fourth course says "along the aliquot line" you have no choice but to accept the aliquot line where it is.
Also you give no information as to the ownership status of the northerly parcel. Mostly that would establish how deep the doo-doo you are jumping in to.
Posted : July 31, 2012 5:23 pm
Keith
(@keith)
clearcut
Hmmmm, they must have had a good reason to go against the Manual guideline on closing corners?
Posted : July 31, 2012 5:38 pm
My take is someone took the good faith action of hiring a Surveyor to mark their corners. The Surveyor did a pretty good job.
There is no requirement of perfection in the law.
The boundaries are established already. The corners are existent. Re-laying out the Deed is inappropriate when the corners are already existent.
Posted : July 31, 2012 6:16 pm
Page 1 / 7
