A couple of good reasons to like a Javad LS
Here, this first pic, shows the 1/4 corner. It is not a very good place to RTK GPS.
Here, you can see that all 10 "Buckets" are full. The next thing it did, was dump everything, and start over.
The first shot, took about 10 mins. VERIFY was turned off. It was a bad shot, by 8 feet.
I then turned VERIFY on, and shot it 4 more times. All 4 were within 0.06' of each other. I was on the point a total of around 50 minutes.
The wrong shot, sort of scared me.... So, I wanted to really check things, and shot, and re shot it, until, I realized it was good. Some shots were up at 12' tall pole, some at 8', and others were down at 5 ft.
I had left the setting in the LS at 5 ft, and so I don't have a very good verification of the elevation of this shot. Maybe next time. OR, If I knew the exact length of my pole, at the 8' and 12' settings, which I don't know.... I was after the horizontal position.
If I were to try to get this shot, with my old GPS, and the Satellites were in PERFECT configuration, It would take me a MINIMUM of 2 hrs. I suspect it would waste 1/2 a day, due to it getting BAD fixes. And, I feel I'd have to have at least 3 that agreed with each other. At different times. It would be a 1/4 mile traverse to get this, with total station, from a nearby field.
Nate
Posted : February 7, 2016 6:12 pm
OOps, I left this shot out. I just got IrfanView Photo Editing going in this computer. This was supposed to be uploaded.
Nate
Posted : February 7, 2016 6:21 pm
Nate,
Does the shoestring bail cause miltipath when filling the bucket?
DDSM:beer:
Posted : February 7, 2016 6:22 pm
I don't think so, Dan. But, it did cross my mind! 🙂
Posted : February 7, 2016 6:32 pm
I'm glad you got your Javad equipment, Nate. You seem happy with it.
You'll probably name your next kid after it....;-)
Posted : February 7, 2016 7:49 pm
Naw, but I have run so many miles of traverse, And set so many offset points, to traverse in from, and waited around in the woods for a fix, that I felt I could rely upon, that it's surveyors heaven!
Posted : February 7, 2016 8:50 pm
Guest
Sounds good and certainly fun!
Have you tried measuring two or three points about 1 metre, 3 ft å± apart and measuring distance with a tape?
It's the final test I'd want it to fly through if I had one.
Posted : February 8, 2016 12:40 am
