Weir Detail
I am looking for a detail for a simple concrete weir?
Like a 1'x8'x3' ish type thing with maybe some rebar in it.
No side forms, just a backhoe hole with the top set at the critical elevation, and the concrete can mesh into the existing soil on the sides and bottom....etc.
Do you have such a thing you are willing to share with me in dwg?
ott@mainstreetconsulting.com
Thanks, Brad
Posted : July 2, 2015 12:06 pm
(@pls30820)
Bob Weir?
Posted : July 2, 2015 12:37 pm
(@ridge)
Google search
design concrete weir wall
or
concrete weir design
Some things to consider is seepage around the concrete and scour downstream of the drop.
Sort of a base for rebar is .0025 of the area (T&S steel). Water structures need plenty of steel, cracks in a water structure wall cause corrosion of the steel and freeze thaw chips away at the concrete.
NRCS might have some engineering standards you could use.
Posted : July 2, 2015 12:42 pm
(@cptdent)
Like this??
overflowweir_0.pdf (53.2 KB)
Posted : July 2, 2015 6:40 pm
For everything you might ever need to know about basic structural design for simple concrete and frame structures check out the resources of the Midwest Plan Service housed on the campus of Iowa State University. Their Structures and Environment Handbook is one of the handiest reference books you'll ever see. The Farm and Home Concrete Construction handbook is far smaller but may be of significant help for do-it-yourselfers. Google it.
Posted : July 2, 2015 7:55 pm
(@wilba)
(@cptdent)
wilba, post: 325675, member: 9024 wrote: Instead of a weir have you considered...
http://evidence.environment-agency.gov.uk/FCERM/en/SC060065/MeasuresList/M4/M4T1.aspx
http://www.allingtonlock.co.uk/eastlockcanoepass.php
http://www.medwaycanoetrail.co.uk/Porterscanoepass.php
Now you've done it!! It's all metric!! Brad will be catatonic for days!!
Posted : July 3, 2015 10:32 am
