Trying to process fieldgenius .raw in Carlson
2 Users
ncdan
(@ncdan)
I have multiple rtk locations collected with fieldgenius that I would like to average in Carlson survey raw editor just as described in the attached video. When I first imported the raw file all the store records were set to ƒ??PTƒ?. I tried to process the raw file straight from the collector but only got an error message of ƒ?? no gps data in fileƒ?. I then changed all the store records from ƒ??PTƒ? to ƒ??GPSƒ? to match the raw file in the video. At this point I thought I was getting somewhere, but then I got the error message shown in to photo. Iƒ??m stumped. I have looked through all the settings to change from SPC to geodetic but canƒ??t seem to get things sorted out. Any help or advice would greatly be appreciated.
Posted : January 21, 2022 7:26 pm
terminus-nc
(@terminus-nc)
It appears that your raw file is coordinates only and the software doesn't recognize it as GPS observation data. If you look at the error picture you will note that the latitude cannot have a value in 900,000 range and has to be 0 to 360.00. My suggestion is to get field genuis to output a file with the observations in lat/long and then in the raw editor use the import (under file) command to bring in the data. I don't run field genius, so don't know what the proper export format is to work with Carlson.
Posted : January 22, 2022 8:54 am
