Trimble access and tablets
15 Users
(@gmpls)
Honorable Member Registered
I love my TSC7 but the touch screen does not work well in the rain. Maybe I should be looking for a rain setting. If the T7 and T10 have similar rain performance, I would not want one since there is no physical keyboard to fall back on. The screen is easy to view though, even in bright sunlight.
Gregg
Posted : 19/11/2020 3:16 am
(@christ-lambrecht)
Noble Member Registered
@gmpls
switch to stylus mode when raining, little blue symbol on the taskbar, there's also a glove mode.
Posted : 19/11/2020 8:39 am
(@ralphieboy)
Trusted Member Registered
I hope Iƒ??m not hijacking the conversation but, you guys seem perfect for my questions. I have difficulty with my Yuma 2, in seeing enough detail with the s7 vision/video, to keep my eyeball off the lens with DR. ?ÿDo you think the T7, T10 and/or Tsc7 will dramatically improve this issue? ?ÿAny chance to improve the latency with turning to the screen touches? ?ÿI currently use 2017.24 and maybe the newer access has some help as well?
Thanks in advance, happy Thanksgiving!
Posted : 26/11/2020 5:07 am
(@robertusa)
Reputable Member Registered
The TSC7 has the same size screen as the Yuma 2, 7". The detail from video with the S7 is the camera in the S7 which is 5 MP. So in order to see things further than say 100 feet away you need to digital zoom in. I used to do that for DR measurements when I used a S6. You don't get detail but you can tell when you're on a building corner. So getting a different or bigger tablet won't really help.
Posted : 26/11/2020 9:10 pm
(@stephen-ward)
Famed Member Registered
@ralphieboy the latency still exists with an S7 / T7 combo.?ÿ I suspect that it's a function of image size and the speed of the radio link.
Posted : 26/11/2020 9:29 pm
(@gmpls)
@christ-lambrecht
Thanks Christ. I remember that setting now but never thought to change it in the rain.
Gregg
Posted : 27/11/2020 3:14 am
(@ralphieboy)
@stephen-ward
Thanks Stephen. ?ÿSince you have used both, do you find that the quality of video and latency are improved between the older Yuma2 and the newer tablet? The video is being transmitted though uhf to the DCs and displayed electronically, obviously. ?ÿMy other experience is using an SX-10 and the tsc7, where the video detail was clearer. ?ÿ
Posted : 27/11/2020 4:46 am
(@hakimjacob)
New Member Registered
Hi...Trimble Access 2018 and on utilize the Trimble Sync Manger measure. This uses Trimble Sync Manager in the workplace to make occupations prepared for download and use in Trimble Access.
On the off chance that you wish to make information documents accessible to any regulator associating with the undertaking without making occupations it is conceivable to transfer the records as venture reference records utilizing the Trimble Sync Manger work area application.
Posted : 04/01/2021 9:10 am
Share:
