I am needing to add a station equation to a VAL. The way it has always been done at my office is adding or subtracting the appropriate value when entering the VAL stations. It just seems like there should be a better way. The station equation has already been added to my HAL. Any suggestions?
Thanks in advance for the help!
Desirea Bussie
FBL and Associates
Maybe I'm not following, but can't you just connect the 2 sections with a straight line? Create it up to the eq, then connect to the start of the second section. If it's in a vertical curve may have to do some trimming to get it right. Make sure you don't create 2 xlines if its an overlapping equation,
I'm sorry, I don't think I explained my problem very well. I guess what I really want to know is if there is a way to add a station equation to a VAL. I know you can add one to a HAL but I need to be able to add the same equation to the VAL.
I'm still not following. When drawing the VAL I would draw it up to the equation back station, then start another VAL at the ahead station and finish drawing it. Then connect the ends at the equation so it's a single VAL.
email is eddycreek@gmail.com if you want to discuss.
Desirea,
Did you sort out this problem?
For this or any other solutions just email us.
Support@geocomp.com.au
Regards,
Jerry
Yes, the post above yours from Eddy Creek worked perfectly for me. Sorry I forgot to update this.
