Terramodel Road guru
(@old-shatterhand)
I work on a roadway project. I have a roadjob with two roadway (left end right). The template & the subgrade editor show everything is good, but when I generate DTM only the finish design's DTM work on both side, the subgrades only in the left side.
What am I doing wrong? Can you help me?
My English is poor. Sorry!
This is my template:
Posted : 16/01/2015 1:45 am
(@eddycreek)
What do you mean by saying it doesn't work? Does not generate dtm on the right side? I assume you have xlines created on both sides attached to the same centerline.
Posted : 16/01/2015 7:34 am
(@old-shatterhand)
Sorry, I was at hockey training. I'm here again.
Yes does'nt generate point and breaklines (DTM) on the right roadway.
I have one real centerline and two paralell line referenced to the real centerline. This two is the roadway's centerlines, where the vertical alignment is valid. (21=road number, bal=left, jobb=right)
I think, if I use a roadway can not attach the same centerline
Posted : 16/01/2015 12:17 pm
(@eddycreek)
It may not have anything to do with your problem but in that last screen shot it looks like the centerline is actually offset slightly to the right of zero. Maybe somehow its not connected though it looks like it is? When you generate the subgrade dtm is the center point generated at 0 or some small offset, and should it be at 0?
Posted : 16/01/2015 1:51 pm
(@old-shatterhand)
When uploaded this phoo, I look that too, and make some changes, but not "work".
Posted : 16/01/2015 2:20 pm
(@eddycreek)
Are you using a shape for the subgrade that goes up to centerline from each baseline? If so, try using a shape of 1 ft or meter at +2.5% instead and then use a Hal transition to make each of those shapes transition to the road centerline. I'm just guessing but it would seem to be caused by something not connecting at centerline.
Posted : 16/01/2015 3:03 pm
(@old-shatterhand)
Thank you for your answers, I will try it. My email is valid, if you have a problem feel free ask me. Keep the connection.
Thanks!
Posted : 17/01/2015 2:02 am
(@jerryc)
Send your file to support@geocomp.com.au and we will put it through our Terramodel support services ( http://www.geocomp.com.au/support/).
Regards,
jerry.:-)
Posted : 20/01/2015 1:40 pm
