Hi All,
Does anyone know if there's software other than Terramodel which can directly import a Terramodel .pro file?
I know that it's possible to view a .pro file in Trimble Business Centre, but was wondering if there's any other software which can import .pro files as well.
My end goal is to import and export a Terramodel file to a dxf or some other format which Liscad can then import without the need to use Terramodel itself.
Thanks 😀
Heidi Belbin, post: 392499, member: 12146 wrote: Hi All,
I know that it's possible to view a .pro file in Trimble Business Centre, but was wondering if there's any other software which can import .pro files as well.My end goal is to import and export a Terramodel file to a dxf or some other format which Liscad can then import without the need to use Terramodel itself.
Thanks 😀
You can Import a TM.pro and then select whatever and Export a dxf in TBC.
Spectra Precision Foresight, but I believe it to be built on the Terramodel engine.
