TDS Recon Pocket PC Repair
bow-tie-surveyor
(@bow-tie-surveyor)
Does anyone know where to send a TDS Recon Pocket PC for repair?
While working in the rain today, the screen froze up and went blank with just vertical stripes. I have dried it out and have been charging it, but so far no luck. I have a backup data collector, but I hate having to redo work.:-(
The Bow Tie Surveyor
Posted : February 26, 2013 2:46 pm
T-Ray
(@t-ray)
I'd get in touch with Trimble's Regional Service Center in Dayton Ohio.
[email protected]
1-888-409-2904 option 4.
Posted : February 26, 2013 3:34 pm
cwlawley
(@cwlawley)
Transit and Level Clinic, NC
919-467-7782
Posted : February 26, 2013 3:36 pm
bow-tie-surveyor
(@bow-tie-surveyor)
Well... I do have some good news. It finally did reboot after about 5 hours of charging. I'm not sure if that was the problem, because I had charged it the night before and had only used it for 4 hours at most before it crashed. But anyway, I was able to retrieve my lost data. However the touch screen is not working. I'll let it sit for a little longer to see if it improves. Now if it does, do I trust it?
Posted : February 26, 2013 4:15 pm
tb91506
(@tb91506)
> 919-467-7782
Yes
Posted : February 27, 2013 9:57 am
Old Stone
(@old-stone)
Bow Tie
Have had the same problem in the past. Turn the unit on, pull the battery off the back, and then side it back on. This will cause a hard reset. Has fixed my screen several times.
Posted : February 27, 2013 8:01 pm
bow-tie-surveyor
(@bow-tie-surveyor)
> Bow Tie
Yeah, I tried that for a few hours. After about 5 hours on charge, it was finally able to do a hard reset. I have got the Recon running again. I upgraded it to the latest firmware version, so, I hope that does the trick. The crash happened when I was working in the rain. I'm not sure if that had anything to do with it or not. I did a test run in my back yard and it appears to be working OK. I am taking it out on a real job tomorrow, but I am taking an old Husky FS2 as backup. I am still learning all of the quirks of the TDS Recon and I think I need a backup battery for it.
Posted : February 27, 2013 8:14 pm
jimmy-cleveland
(@jimmy-cleveland)
Bow Tie,
The backup battery is a good idea. My buddy was working on a job for me about 4 hours from home. It was a long day, and not long after he had started using his Nomad. He was about 30 minutes from finishing, and had to call it a day because it was getting dark, and the data collector battery was dead. Hard to run a robot without a data collector.
He bought the backup battery adapter that takes the AA batteries, and it has saved the day on more than one occassion. I think his was about $140 from Hayes.
My old Ranger 200T did something very similar last week. My Ranger 500X battery was getting low, and I was going to upload the job file into the 200T and keep rolling, but my battery was dead, and the screen was doing something like what you describe. I charged the battery, and it works like a champ.
Jimmy
Posted : February 27, 2013 10:04 pm
