At one time my data collector work fine,but lately different story....How do I set up my active prisms so that the repetitions routine is happy... I get the following error message ...
Automatic repetitions require backsight and foresight targets with active prisms Please check your backsight and foresight smart targets.... I use only rmts that are active..... so I must be forgetting a check box someplace...
THANKS FOR YOUR HELP
Aloha, Dane:
I went through this recently...I have Survey Pro 5.4
1. Automatic Repetition routine only work when both prisms are with RMT
2. Each with unique IDs
3. You must create two "smart targets" in your Manage Smart Target" tab and one of these must be selected for BS and FS
4. In the Repetation tab check the "enable automatic Repetition" You obviously have this checked to get the messages.
If you have all of the above done and it is still not working...make sure you RMT's batteries are fully charged.
NOT a TDS guru by any means; however, may qualify in other areas :angel:
That's cool - ask for guru and get a swami!
That's a lot of progress.
