TBC won't open .vce file
2 Users
I have a .vce file created by someone else on a different computer that contains some SX10 scan data and traverse, VRS, etc. Both my PC and the other PC are running TBC V5.10. I tried to upgrade to V5.20 but it caused a problem (which I posted about) and have not yet tried again to update.
I transferred over the .vce file and the subdirectory with the same name, which I always do. But, when I try to run it I get this message:
I have tried several times, recopying, etc. And he is able to open it on his machine. I see nothing wrong with the path name or file name.?ÿ
Posted : 10/02/2020 9:48 am
(@fairleywell)
Try pressing Ctrl+Alt and drag and drop the vce file into the plan view.?ÿ I'm not sure if it will still work, but it used to.
Posted : 10/02/2020 11:07 am
Now it turns out he has the same problem. On his PC he created the TBC project on his G drive, and when he moved it over to C drive and tried to open it, same problem. Both are ssd drives on his PC.?ÿ
Posted : 10/02/2020 12:06 pm
Look like 5.20 resolved the problem. I was hesitant to install 5.20 because last time it somehow messed up the processor, and I was in a time critical mode where I needed to deliver a project urgently, so when that happened I uninstalled 5.20 and reinstalled 5.10. Not sure what happened, but it seems to be OK now.?ÿ
Posted : 10/02/2020 2:10 pm
