SurvCE: Moving points from one job file to another?
To minimize the effects of blunders, I've gotten into the habit of creating new job files for the expansion of my control network. I also like to keep my topo sessions separate from the control network expansion sessions. But if one is in the field, creates a new point (not currently in the Control File), then starts a new Job say, to do some topo, that recently created point doesn't show up in the new Job file.
Is there a way (short of manually adding the point to the Control File), to import points from another job file, into a new job file (or adding them to that new job's Control file)? I want to do this in the field, with the field software.
Posted : October 7, 2016 3:15 am
(@bow-tie-surveyor)
Under the file tab, use the Import/Export button to export the points you want to an ASCII file and then import them into the job you want.
Posted : October 7, 2016 4:30 am
Carlson XPort and SMI Transfer are two programs I use to manage and combine and extract information from one file to another outside the collector.
I've always rather use a big screen showing both or multiple files at the same time while manipulating the creation of new and improved version.
I look at it as preserving the original file and picking what I want from other files and adding to a new file that is customized to the current project.
Posted : October 7, 2016 8:51 am
Bow Tie Surveyor, post: 394290, member: 6939 wrote: Under the file tab, use the Import/Export button to export the points you want to an ASCII file and then import them into the job you want.
That worked perfectly. Don't know why I never tried it before; always used it just to import/export to/from the control file.Could have saved myself a lot of time had I tried this months ago. Thanks very much!
Posted : October 7, 2016 11:59 am
