Greetings,
I installed SurvCE 3.03 on a Topcon FC-250 data collector. When I try to use the Point Inverse screen, it prints the text against a blocked-in black background. When I tilt the screen I can see the faint text against the black background.
I re-installed SurvCE per the advice of Carlson support, but that did no good. They appear to be baffled by this problem., having never encountered it before. I figure the problem must be due to some text setting in either SurvCE or the FC-250.
Has anyone else run into this?
Thanks.
I have not ran into that issue but I have a weird one too with an Allegro MX. When holding the ALT button and pressing any key the software chooses to do absolutely nothing. So all those nifty shortcuts don't work anymore.
Yes, I am having this problem too. I want my "ALT P" back!
The Alt-key problem has been resolved, and a fix is available in a patch version of the software, if you call tech support. Sorry for the inconvenience!
