Surface Area of TIN in Carlson Survey 2010
(@cf-67)
Can you? How? Not the horizontal area encompassed by the TIN but the actual surface area. Seems like it should be in there, but I can't find it.
Thanks
Posted : June 29, 2015 3:45 pm
(@cf-67)
Colin Frank, post: 325076, member: 7027 wrote: Can you? How? Not the horizontal area encompassed by the TIN but the actual surface area. Seems like it should be in there, but I can't find it.
Thanks
Or...if it's a 3:1 slope can I multiply the horizontal area by...errr...come on brain, work!
Posted : June 29, 2015 4:07 pm
(@twdotson)
Look for Slope Report on the Surface menu? It may not be included in your package.
Posted : June 29, 2015 4:40 pm
(@cf-67)
twdotson, post: 325082, member: 8059 wrote: Look for Slope Report on the Surface menu? It may not be included in your package.
It isn't unfortunately - in "Civil" but not "Survey"
Posted : June 29, 2015 4:43 pm
(@twdotson)
If you want, email a drawing of the 3dFaces to dotson [at] dotsoft [dot] com and I'll reply with the 3dArea. Might be able to read the .TIN file, not positive about that.
Posted : June 29, 2015 4:58 pm
(@cf-67)
Done. Thanks!
twdotson, post: 325084, member: 8059 wrote: If you want, email a drawing of the 3dFaces to dotson [at] dotsoft [dot] com and I'll reply with the 3dArea. Might be able to read the .TIN file, not positive about that.
Posted : June 29, 2015 5:18 pm
(@ladd-nelson)
Colin Frank, post: 325083, member: 7027 wrote: It isn't unfortunately - in "Civil" but not "Survey"
I did a little digging... see if the sarea key-in command gets you what you need.
Posted : June 29, 2015 6:02 pm
(@cf-67)
Wowsers! First Mr Dotson was kind enough to run the TIN through his software, then Mr Nelson discovered a hidden command (it worked) - all in a few hours. Good old SurveyorConnect!
(even my ball park handcalc seemed to work - hypotenuse/horizontal for 3:1 slope = 1.05 x horizontal area....)
I know exactly how much Bentonite we need! (some kind of clay for sealing earth dams....never heard of it 'til a week ago..no relation to kryptonite:bye:)
Posted : June 29, 2015 6:25 pm
