Station Offset Carlson Intellicad
(@timay91)
Active Member Registered
Hello All,
I've been tinkering around with Carlson Intellicad and overall I'm pretty impressed. The programs supply most of the tools I need without any of the bloated complexity that is C3D. However I am running into a small issue which I am guessing is due to my own inexperience and not the software itself.?ÿ
I am trying to find a way for my station/offsets to auto update in the point description after a change is made to the CL/Alignment file. I've tried the link commands under SETTINGS>CARLSON CONFIGURE>GENERAL SETTINGS (I have also tried this in Carlson running on top of ACAD before my license expires). Though this does not seem to work either. I was also thinking there should be a way to define this in F2F by just rerunning the command with the points of interest but I also cannot find what I am looking for there.
So after that longwinded post my question I guess is, is this even possible in Carlson? Or am I just banging my head against the wall?
Thanks in advance,
Posted : 21/12/2022 11:35 am
(@va-ls-2867)
Honorable Member Registered
I assume you are setting points using the offpts command. Easy answer is no, the descriptions do not update with a change in centerline definition.?ÿ The point blocks are not active objects like in Civil3D.
Posted : 21/12/2022 12:19 pm
 Remi
(@remi)
Eminent Member Registered
@va-ls-2867 be really careful with C3D doing that had a project a few years ago had to adjust the alignment by about 0.25. only about half the station offsets updated
Posted : 21/12/2022 12:21 pm
(@va-ls-2867)
@remi I detest using Civil3d, I use Carlson running over Civil3d.
Posted : 21/12/2022 1:22 pm
 Remi
(@remi)
@va-ls-2867 Hi agreed C3D has never lived up to it promises, in many ways its not as good as LDT.
Posted : 22/12/2022 7:22 am
Share:
