For the last decade our software for creating plan and profile sheets was a compilation of routines written by a friend of mine who is no longer surveying. They worked fine for him and our 32 bit machines. Now he is not available and the guys I have now are having compatibility problems with some of the routines. We need software that will run in the latest versions of Autocad on 64 bit computers. Our old software would take an ascii file with standard P,N,E,E,Desc format and create station and offset data along with creating a profile. What do you guys use to make your P&P sheets?
Carlson Survey
a little bit of effort to learn the way it likes input but everything is in there. makes a great drawing.
> Carlson Survey
:good:
Carlson. Once you get the settings right, it's a piece of cakeMultiple profiles on one sheet, you can annotate design and existing elevations, etc.
> > Carlson Survey
> :good:
:good:
