I tried the online carlsonemea file viewer using the same source file (see below) that i used in my post above. The first half (approx) of the output agreed with the Copan output, but four out of five observations were missed!
JB,NMK05-158,DT07-26-2005,TM11:09:39
MO,AD0,UN1,SF1.0,EC0,EO0.0,AU0
SP,PN1,N 5000.0,E 5000.0,EL100.0,--Start
--Activating Total Station: Leica TPS Series [TCR405], COM1, 9600 baud, no parity
SP,PN2,N 5577884.876,E 681675.723,EL838.194,--CP
SP,PN1,N 5578066.198,E 681604.833,EL845.574,--CP
OC,OP1,N 5578066.198,E 681604.833,EL845.574,--CP
LS,HI1.892,HR1.47
BK,OP1,BP2,BS158.3847,BC0.0000
--HR at Backsight: 1.757
--BS check 1 - 2:ZE109.1725,SD17.806,HD err= -177.880764, VD err= 1.632712
--BS Circle check : angular err= 75.1525
--BS check 1 - 2:ZE92.1245,SD194.855,HD err= 0.022657, VD err= -0.007536
--BS Circle check : angular err= 0.0000
LS,HI1.892,HR1.757
SS,OP1,FP100,AR0.0000,ZE92.1245,SD194.854,--cp
CF,EL839.256765,GD838.186503
DE,PN100,N 5577884.855829,E 681675.730886,EL838.186503,--cp
SD,ND-45.373035,ED17.746729,LD-1.070262
SK,OP1,FP5,AR0.0010,ZE92.3835,SD146.144,--CP842
SP,PN7,N 5578035.739098,E 681616.74042,EL842.500182,--CP840
CF,EL842.500182,GD838.194
DE,PN2,N 5577884.876,E 681675.723,EL838.194,--CP
SD,ND-150.863098,ED58.98258,LD-4.306182
SK,OP1,FP7,AR0.0005,ZE96.0605,SD32.89,--CP840
OC,OP7,N 5578035.739098,E 681616.74042,EL842.500182,--CP840
LS,HI1.555,HR1.757
BK,OP7,BP2,BS158.3846,BC0.0000
--BS check 7 - 2:ZE91.2705,SD162.067,HD err= 0.031613, VD err= -0.000782
--BS Circle check : angular err= 0.0005
--BS check 7 - 2:ZE91.2705,SD162.065,HD err= 0.029614, VD err= -0.000731
LS,HI1.555,HR1.47
SP,PN101,N 5578025.353318,E 681541.677606,EL837.21428,--gnd
CF,EL837.21428,GD838.186503
SD,ND-140.497489,ED134.05328,LD0.972222
SK,OP7,FP101,AR103.2835,ZE94.0315,SD75.968,--gnd
Martin,
I've been in touch with the developer of that today.
The UI is not all that intuitive.
You need to select the "Total station" (top left "Select report type") option.
I made the same mistake.
I made a file out of your data to test it. And it's fine. My program loads what ever you give it regardless.
Me and the developer are emailing back and forth about differences between report types. His may do some stuff far above simple viewing which is what I built and am re-building. My new version is already allowing you to edit stuff - within reason of course (can't change record type codes --- bad bad dog!) 🙂
I won't divulge details but will say it was built for the European users and they are apparently heavy on GPS reports which is what the site defaults to. I don't have a clue how much time was spent on the web based thing you tried but I have mine loading files and displaying everything (maybe not pretty - yet) and you can now edit about a half-dozen record types.
Try again.
E.
I definitely did have Total Stn selected (i double-checked just now).
When you tried with my data:
Did you get the same results that Copan gave (repeated here)?
job= K05-158 dat= 07-26-2005 tim= 11:09:39
;; SF= 1.0 PC= 0.0"
// pnt= 1 N= 5000.0 E= 5000.0 Z= 100.0 cod= Start
// pnt= 2 N= 5577884.876 E= 681675.723 Z= 838.194 cod= CP
// pnt= 1 N= 5578066.198 E= 681604.833 Z= 845.574 cod= CP
// pnt= N= 5578066.198 E= 681604.833 Z= 845.574 cod= CP
at= 1 ref= 2 HC= 0.0000 HI= 1.892
to= 100 HC= 0.0000 VC= 92.1245 SD= 194.854 HS= 1.757 cod= cp
to= 5 HC= 0.0010 VC= 92.3835 SD= 146.144 HS= 1.757 cod= CP842
// pnt= 7 N= 5578035.739098 E= 681616.74042 Z= 842.500182 cod= CP840
to= 7 HC= 0.0005 VC= 96.0605 SD= 32.89 HS= 1.757 cod= CP840
// pnt= N= 5578035.739098 E= 681616.74042 Z= 842.500182 cod= CP840
at= 7 ref= 2 HC= 0.0000 HI= 1.555
// pnt= 101 N= 5578025.353318 E= 681541.677606 Z= 837.21428 cod= gnd
to= 101 HC= 103.2835 VC= 94.0315 SD= 75.968 HS= 1.47 cod= gnd
Or did you get this, which contains only one of the four observations
Rec_Desc,Rec_Type,"Point ID",Description,Inst_Height_,"Rod Height","Horiz_ Angle","Vert_ Angle","Slope Dist",Local_N,Local_E,Local_Z,PC,"EDM Mode",SF,DATE,TIME
"Stored Point",SP,PN1,Start,,,,,,5000.0,5000.0,100.0,,,,,,,,,,,,
"Stored Point",SP,PN2,CP,,,,,,5577884.876,681675.723,838.194,,,,,,,,,,,,
"Stored Point",SP,PN1,CP,,,,,,5578066.198,681604.833,845.574,,,,,,,,,,,,
"Occupation Point",OC,1,CP,1.892,,,,,5578066.198,681604.833,845.574,,,,,,,,,,,,
Backsight,BK,,,,,,,,,,,,,,,,,,,,,,
"Side Shot",SS,100,cp,,1.757,"0 00 00.","92 12 45.",194.854,,,,,,,,,,,,,,,
"Stored Point",SP,PN7,CP840,,,,,,5578035.739098,681616.74042,842.500182,,,,,,,,,,,,
"Occupation Point",OC,7,CP840,1.555,,,,,5578035.739098,681616.74042,842.500182,,,,,,,,,,,,
"Stored Point",SP,PN101,gnd,,,,,,5578025.353318,681541.677606,837.21428,,,,,,,,,,,,
And what do you get with your software?
Dear Martin,
May I ask which program generated this RW5 file?
The online report generator at the CarlsonEMEA website is designed for Carlson .RW5 format generated by SurvCE.
Thank you in advance,
greetings,
Floris.
Nothing else to do at this moment
I think that's changed by now 😉
Greetings,
Floris
