Problem with SID viewer in LDD
(@david-livingstone)
I recently obtained a new computer that is running Windows 7 and is a 64 bit machine. I've tried to load the SID viewer that lets you load aerial photos into your drawing. So far no go. I have the 64 bit version, but when I try to install it, its says it has an error changing the acdb17.dll file, like I don't have permission to change it or some other kind of problem.
Anybody else run into this?
Posted : June 20, 2013 10:44 am
(@bryan-newsome)
What flavor of LDD?
I am running LDD 2004 on a Windows 7 64-bit and have no trouble inserted SID(s) in my cad files.
The later versions of LDD switched that off if I remember correctly.
You can download Lizardtech's Geoviewer, import your SIDs, and write out smaller image files with the World Files.
Posted : June 20, 2013 1:56 pm
(@bobwesterman)
Are you talking about the raster object enabler? I had some error message when I installed it. Don't remember message, finished install. I always got an error inserting image through map, abort, cancel, ignore, one day I tried ignore, had to hit ignore 3 times but it always puts the sid file in, and in the right place. This is LDD2007.
Posted : June 22, 2013 6:22 am
