point tables w/stationing
5 Users
(@aaron23)
Has anyone found a decent work around for this w/out having to invest more money into Civil 3D third party software?
table
PT #/N/E/ELEV/STA/OFF/DESC?
Posted : August 25, 2014 12:48 pm
(@aksuperchamp)
Nope.
I use and recommend this: http://www.quuxsoft.com/
Posted : August 26, 2014 11:08 am
(@frank-baker)
I've had some luck with this. You might have to convert it to Excel....
http://docs.autodesk.com/CIV3D/2013/ENU/index.html?url=filesCUG/GUID-252B304E-62D3-4825-B50C-15204D50714F.htm,topicNumber=CUGd30e427218
Posted : August 26, 2014 4:56 pm
(@aaron23)
I found a way to do this. I used the reports manager to create station offset data. Imported it into excel. Then using the "user-defined property classifications" I created a station/offset. Then I created a new point file format to include the "station/offset" and able to import a .csv. Imported the points and it had the station/offset data. The I had to create a new table format to include station offset. Took a bit to figure out but once I did, it goes pretty quick. I saved the drawing as a template for future use.
Posted : September 24, 2014 8:39 am
Way to go.
Never, ever give up.
You must be a surveyor.
Posted : September 24, 2014 9:38 am
(@scott-ellis)
Nice looking table you may want to add the foot symbol to the elevation and Northing, Easting, and offset.
Posted : September 24, 2014 10:00 am
(@aaron23)
My final does. This was test #2300 so I was in a hurry!
Posted : September 24, 2014 10:03 am
