Gotcha. So it’s focused on BIM or any construction. Earthwork etc.
While Leica Infinity doesn't have built-in point layout functionality, there are some good options that work with your Leica equipment and avoid the Revit + plugin route:
Autodesk Point Layout - This software directly connects your 3D model (from various BIM software) to field layout workflows. It integrates seamlessly with Leica Geosystems instruments like your TS16 and data collectors running Captivate or FieldGenius. You can export points directly for stakeout and even push them to the BIM360 Layout mobile app for real-time collaboration.
Trimble Field Link: This software caters specifically to construction layout. It allows you to create 2D and 3D points directly from your existing design files (AutoCAD, Revit, SketchUp) and works with Trimble instruments. While it might not be your exact brand preference, it's a strong contender with proven efficiency gains for layout projects.
If you anticipate complex projects requiring BIM integration, then Autodesk Point Layout might be a future-proof option. It provides a strong bridge between design and field execution.
Check out Trimble Access YouTube channel at the latest features for BIM staking in Trimble access 2024. They just released this version a little bit ago but some added benefits in what you are looking at doing.
