Offset & Fillet
(@spledeus)
Once in a while I find a rogue drawing with the setting to offset and fillet a polyline all at once. Then I go to most of the drawings and it's the same humdrum: offset then fillet. Two separate actions, then you get to edit the offset line because the arcs never swing when the backtangents are short.
Posted : October 19, 2012 8:18 pm
(@perry-williams)
Try BOFFSET
Try BOFFSET. It offsets and fillets in the same operation.
Posted : October 20, 2012 12:13 pm
(@gromaticus)
Thanks for asking this question - I had the same problem!
This works in ACAD 2013:
Set "OFFSETGAPTYPE" to 1 and the OFFSET command will automatically fillet the offset lines.
If you set it to 2, it chamfers the offset.
Jeff
Posted : October 21, 2012 5:43 am
