Nomad/Windows 10 compatibility issue
(@c-billingsley)
I recently switched my work computer to Windows 10. Since then, I haven't been able to get my Nomad to connect. I'm thinking it's probably a driver issue, but I don't know exactly what. Has anyone else had this problem? If so, do you know what drivers I need and where to get them?
Thanks!
Posted : September 22, 2015 4:04 pm
(@randy-rain)
Settings can be found in the sync center in control panel (windows key + 'x' then select control panel). Spend some time in there with the settings you should be able to get them to talk. I don't have a nomad here or I could give you more specific instructions.
Posted : September 22, 2015 4:47 pm
(@c-billingsley)
Randy Rain, post: 337523, member: 35 wrote: Settings can be found in the sync center in control panel (windows key + 'x' then select control panel). Spend some time in there with the settings you should be able to get them to talk. I don't have a nomad here or I could give you more specific instructions.
I managed to get it to work. Just had to uncheck a box in the data collector. Thanks!
Posted : September 25, 2015 10:37 am
(@jules-j)
Unchecked what box? So we will know.
Thanks
Posted : September 25, 2015 10:41 am
(@c-billingsley)
I unchecked "Enable advanced network functionality" under "Conncections", "USB to PC"
Posted : September 25, 2015 10:49 am
(@jules-j)
Thanks! Found it. My box was unchecked.
Posted : September 25, 2015 10:56 am
