Need help converting a .see Liscad file
2 Users
(@azweig)
Can someone with Liscad convert a .see for me into either a .dwg or .dxf? Thanks in advance.
Posted : October 22, 2015 5:49 am
(@john-putnam)
azweig, post: 341488, member: 7041 wrote: Can someone with Liscad convert a .see for me into either a .dwg or .dxf? Thanks in advance.
Azweig,
Do you know what version of LisCAD the see file is from. Also do you have the code and plot files that the drawing associates with? They are not stored within the see file. If so, I may be able to help you out.
Posted : October 23, 2015 6:50 pm
(@azweig)
John,
I have no idea what version it is. It is probably whatever version was current 3-4 years ago. I do not have any of the code or plot files either. I was looking into an older project that I had done to help someone out with their current project, and saw the .see file in my files. The company I worked for at the time used Liscad, but since leaving there, I do not use it. I was able to send them some cad files from my project, I think it will be enough for them. Thank you for your offer.
Posted : October 26, 2015 4:26 am
