If you repeat a BS shot, the accumulated BS distances are incorrectly calculated.
When you bring the MJF file into Magnet Office Tools you can delete your bad setup.
Just as with an original paper field book. All data is recorded, never erase. Only cross out and continue to show your work. The corrected data will be adjusted in the office. So it may not be a bug.
Now there is one pita bug in latest version of Magnet Field that burns my a$$. I have been using an external Bluetooth to UHF radio with RTK rovers such as Hiper SR and Sokkia GCX2 that don't have UHF radio. This has worked flawless until release 4.3.2
Magnet is no longer prompting end user to connect to the external radio, using exact same parameters. This will take weeks or months for me to get Topcon to fix.
BTW, still broken in last week's release 4.3.3 of Magnet Field.
