I have a field crew that is using Magnet data collector Software and cannot figure out how to send me the Raw data so I can identify/adjust points observed from the incorrect setup.
I am in the office working remotely and do not have Magnet software or access to a manual. I thought it would be as simple as going in the menu, selecting export, and picking a format like RAW, RW5, etc.?ÿ But the crew only sends me .mxl files.
Thanks in advance for your help.
Richard.
@muddychief , .mxl is the default raw data I believe, but there is a Format drop down menu in the export to file menu that lets you change it to SurveCE (*.RW5) or TDS (*.RAW).?ÿ
I am running Magnet Field 6.1.2 as well.?ÿ
Correct setup in mjf job file using edit raw. All points shot from setup will be recomputed in the raw file.?ÿ
