Using Carlson Survey 2013, does anybody know why the "line" command doesn't work anymore? I've tried typing "line" and also tried the "line" button in the toolbar, but nothing happens. It was working yesterday!
Thanks for any help.
Line is working here.
Is there a way to maintain settings? I have to change the exact same settings for every file I open. NOT NEW DRAWINGS, but existing ones.
I've noticed that some commands are different, depending on where you issue them from.
For example: type LIST at the command line and it doesn't list the layer. But pick LIST from the pulldown and it does. (After you hit F-2 and scroll up)
just use 2dp. one less letter. think of how much more efficient you'll be with all that time saved and polylines created. 🙂
when you change settings in Carlson stand-alone, use the Carlson dialog from the pulldown menus.
Using the traditional AutoCAD commands will change settings but they won't stick.
