I am using LDT 2007 an lately have been having trouble with the line table having tag lines in them before I even start labeling. They are sometimes without a tag number, but this drawing has 16 L1 and 16 L2 and so on and the curve tables are starting at C3 instead of C1. Does anybody know where the database would be stored or how to remove them so that I can start with L1 and C1. I have a job that I need to get out with about a hundred calls and it takes me a while to edit the line tags, having to reverse line bearings on a lot of lines takes me quit a bit of time already. Any help would be appreciated. TIA
I found them, I am working on grid at about 500,000 and 1,500,000 and they were down at 0,0. I did a zoom extents and found them and erased and reset back to L1 and C1. Good to go.
Well I spoke to soon that fixed my line tag problem, but the curves are still starting at C3 and when I insert the table I have two curves without a curve number twelve times. I can't find this problem. Anyone have any ideas? TIA
I have a lisp program that fixes this - I think it called fixtags
email me if you want it
Thanks, I will.
