Does anyone use Info Retriever by AGT? What are your thoughts on it?
I use it on my network for 9 years now, and have anywhere from 3-15 computers logged in at once. The thing is always slow for me when accessing property records. The Appointments section freezes at times and hangs up the program when you set a reminder.
The firm I worked for before I went out on my own used it for years. I think the computer it was on crashed, and they lost the database.
They seemed to like it. It was a single user from what I remember.
I'm sure if the database is on one machine it would be great, I started out with the Single user and then expanded my database
we use it on a network. Use to have multiple access license, but since gone to a single access license. Seems to work fine, but I wish I had done something different for a database program. Someday I will switch to something better.
What version are you running? I have version 12. If you go to the server where the program and database is running. Goto Start, InfoRetriever... you should see a program to do a database repair. Might help your situation. But make sure you make a backup copy!!!! I am not responsible if it blows UP!
