To justify LEFT instead of RIGHT or center?
I just want to modify the justification.
It was all done the 1st time with DT, or dtext.
Thanks.
Highlight the text and then go to the upper controls in your dialog box and click. It should be the left side of the dialog box once you have clicked in the text you would like to alter.
I don't know what version you have but in 2009 you go for properties (PR), select the text, then in the properties box, change the justification to what you want.
T.W'
I have Standalone, 2009.
isolate all the text layers, lft window and select, in properties choose left justification
I think the properties command is an AutoCad function. If you are using the Intellacad version it may work differently.
T.W.
In older versions with express tools it was "tjust" , would do it. _properties will do it.
Boy... ya'all gonna hafta spell it out, in more detail.... My linear brain would not allow that instruction set to float through....
Thanks for the help.
Nate
