Extracting data in Autocad
9 Users
I'm at a loss here for the right command. I have a large contour map and want to extract a rectangle of data from it.
I don't want to mess around with trimming entities - just specify window and delete everything outside it.
Any ideas?
Posted : June 23, 2017 3:26 pm
totalsurv
(@totalsurv)
How about a viewport in paperspace, you could probably achieve what you need without deleting anything.
Posted : June 23, 2017 3:33 pm
dick emery
(@dick-emery)
If it's just straight AutoCAD (not Civil3D) with just polylines, try drawing a rectangle around the area, then trim-fence outside the rectangle.
Posted : June 23, 2017 3:42 pm
squowse
(@squowse)
Erase command.
Then All to select everything then hold shift down and deaw a window to remove entities from the selection set.
Whether you draw the window left to right or vice versa determines whether objects that cross the window are deleted or not
Posted : June 23, 2017 3:47 pm
The trimming by fence is what I was trying to do, but it kept freezing my computer up.
Posted : June 23, 2017 3:48 pm
XTRIM ended up working for me. I still had to erase the stuff outside the rectangle, but selecting everything inside, then escaping, issuing the delete command, selecting all, then removing prev. selection set did the trick.
Posted : June 23, 2017 3:52 pm
dick emery
(@dick-emery)
It may have been freezing because the properties dialog box was open - if you have it open and you select (or otherwise "attack") a lot of polylines and/or polylines with lots of vertices then it can hang up and freeze while processing them through the properties dialog. (same with other large quantities of objects).
Posted : June 23, 2017 4:16 pm
Nick Jewett
(@nick-jewett)
One method would be to use SELECT with the WPolygon option to select all the objects completely within the polygon boundary.
Posted : June 23, 2017 4:32 pm
Jose Duran
(@jose-duran)
As totalsurv said, use a viewport in paperspace, then export to a new drawing.
Right-click over the paperspace name, the choose export...
Sent from my ASUS_Z00AD using Tapatalk
Posted : June 23, 2017 5:33 pm
squowse
(@squowse)
Jose Duran, post: 433886, member: 11714 wrote: As totalsurv said, use a viewport in paperspace, then export to a new drawing.
Nice didn't know this was possible - but the coordinate system gets lost?
Posted : June 23, 2017 6:37 pm
Jose Duran
(@jose-duran)
Scale and move it to the desired coordinate system.
Posted : June 23, 2017 6:39 pm
bk9196
(@bk9196)
Never tackled this issue, you could try WBLOCK. and then edit out data that's not of concern from the block you created. Might help with the file size lock up issue.
Posted : June 23, 2017 7:21 pm
spledeus
(@spledeus)
Last year I switched to a grid system of tins via carlson. I divided up the town based on lidar via [REDACTED]. I then brought it into Carlson and used inclusion exclusion to eliminate the buildings, water courses, etc.
Now I use RECTANGLE to show my area, triangulation file utilities, inclusion area, save as new tin, contour that file...
Posted : June 23, 2017 7:46 pm
Jose Duran
(@jose-duran)
spledeus, post: 433902, member: 3579 wrote: Last year I switched to a grid system of tins via carlson. I divided up the town based on lidar via [REDACTED]. I then brought it into Carlson and used inclusion exclusion to eliminate the buildings, water courses, etc.
But what happen if imaudiger doesn't have Carlson?
Posted : June 24, 2017 8:19 am
I do have Autocad with Carlson, but was able to accomplish what I needed by using the XTRIM command, which allows you to trim all objects crossing a specified rectangle. I then manually erased the data outside the rectangle.
Posted : June 26, 2017 12:38 pm
navaran
(@navaran)
imaudigger, post: 434149, member: 7286 wrote: I do have Autocad with Carlson, but was able to accomplish what I needed by using the XTRIM command, which allows you to trim all objects crossing a specified rectangle. I then manually erased the data outside the rectangle.
In Carlson:
Edit->Erase->Erase By Closed Polyline
Posted : June 26, 2017 11:10 pm
navaran, post: 434207, member: 1096 wrote: In Carlson:
Now that is slick - exactly what I was imagining.
Thank you for pointing that Carlson tool out to me.
Posted : June 27, 2017 10:47 am
