Hello
I am trying to use Grid Factory to cut a grid of the geode EIGEN-6C4 following the procedure as it is indicated in the manual, when trying to visualize the values it gives me an error (attached image). What could be the reason for this error?
Thanks
Have you cut out a grid before using this geoid model? It looks like you don't have this geoid loaded into the program, or loaded incorrectly, possibly into the wrong file folder.?ÿ
The geoid data were downloaded from the EIGEM-GFZ, and were entered by means of a .txt file with the values of geoid undulation using a grid of 0?ø01'00 '' (1 sec). Anyway, I'll check what you tell me.
Your symbology says 1 minute, but text says 1 second. 1 second would be some serious overkill...
