cut and paste not working?
(@foggyidea)
I have suddenly lost the ability to cut and paste to the google search box. If I right mouse click 'copy,' after highlighting the phrase, and then go to 'paste' it the only thing that happens is that a blank space appears, no text.
Can't paste on this site either...
What setting have I disturbed?
Dtp
Posted : February 7, 2014 8:13 am
(@mapman)
Re-Boot! Fast! 🙂
Posted : February 7, 2014 8:28 am
(@foggyidea)
Now paper space vs. model space
I use Carlson 2008 stand alone. I work n both model and paper space. it used to be that when in Paper space you cold click the radio button to switch back to model space but the view would remain the same as in paper space and you could select and edit model space items. Sure you can mess up the scale if you're not careful and aware, but now I can't pick items in model space when I click the radio button 'paper.'
I have to exit out using the model tab key to edit in that view now...
Posted : February 7, 2014 8:29 am
You using one of the Sochi internet connections?
Posted : February 7, 2014 8:58 am
 vern
(@vern)
Sounds like you may have changed the mouse control parameters somehow, or maybe your mouse has just gone screwy. Do you have another mouse you can try?
Posted : February 7, 2014 9:00 am
(@derek-g-graham-ols-olip)
Don-
I get this result by highlighting, 'copy' and 'paste;
Derek
Posted : February 7, 2014 9:37 am
(@foggyidea)
re-booting did work...
Posted : February 7, 2014 9:41 am
(@curly)
As an alternative, keyboard shortcuts are your friend and work when no right click option is available; control c, to copy, control v to pasta!
Posted : February 7, 2014 9:44 am
